What is a "shift kit?"
I recently bought a Chevy Silverado with a "shift kit" on it. Now, the only thing I know about this thing, is that it makes my automatic transmission shift at a higher rpm than normally and makes in-town gas milage really bad. I have looked at a couple of these online and I think I have a pretty good idea of what it looks like, what I want to know is this: What is it attached to, and how should I go about getting rid of/replacing it to return to normal automatic shifting? Thanks ahead of time for your response.
RE: What is a "shift kit?"
Blacksmith
Thank you very much for your response. It seems from your reply that I will need professional assistance. Thanks again.
Silverado
This is a device (mounts to the case of the transmission) that uses engine manifold vacuum to signal engine load to the transmision.
Less vacuum=more load.
some of these are adjustable.
if a vacuum leak exists, it will "see" less vacuum, and shift "later" as if you had a higher load than you really have.
check it out...
Jay
