linked objects, similar to a block
THANKS IN ADVANCE FOR READING THIS.
In my (model space) drawing I need to have 2 or more identical objects. Easy. The trick is, when I update one of them, I want all of the objects updated. I am looking for an alternative to defining blocks and having to redefine them for every change.
PLEASE HELP,
-John
RE: linked objects, similar to a block
the only option I see other than using blocks is to use X-Refs
www.resourcecad.com ~ for your CAD solutions
I don't see any problems with blocks.
I think "_.refedit" is not redefining.
Lothar
ADT 2004
ACAD 2002
Exxit is right, the refedit is the fastest way to redefine your blocks. Just pick one of them, edit it, and when you close it, the refedit will redefine all instances of the block. Its a fairly nice little block editing routine. Now, if you are talking attributes, that is a different story. Each block has its own set of attributes, and the strings stay with the certain block.
"Everybody is ignorant, only on different subjects." — Will Rogers
