Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Want to thank those people who have made this forum such a valuable place to visit each day..."
Geography
LuisV (Petroleum)
19 Nov 04 13:21
SA-516-70 can be used istead of SA-216-WCB?
metengr (Materials)
22 Nov 04 9:52
What is your intended application? The SA-516 Grade 70 is a plate specification for moderate to lower temperature service. The SA 216 is a specification for carbon steel castings for higher temperature service.
The mechanical property requirements between these two specifications are very similar, with the casting having slightly lower yield strength requirements.
Casting
UTS 70-90 Ksi
YS  36 Ksi min
SA 516
UTS 70 Ksi min
YS  38 Ksi min
Helpful Member!(3)  MJCronin (Mechanical)
24 Nov 04 13:03
Luis,
Your question tells us that you do not understand that ASTM standards are specifically developed for the product form.
SA516-70 is fully killed, rolled carbon steel that would be the plate material used to fabricate the shell of an ASME pressure vessel.
SA216-WCB is also carbon steel, but it is a cast material and would be specified for something like a gate or globe valve body.
hope that this helps...
MJC
Close Box
Join Eng-Tips® Today!
Join Us             Close
