Drived component pattern on curve driven pattern.
First make a curve driven pattern in a part
Then use this for driving a component pattern in assembly.
Is it possible ?
Because I did this by very simple linear curve driven pattern , but sw show this message :
Cant specify start location for pattern
RE: Drived component pattern on curve driven pattern.
What SW version and SP are you using?
I did this in SW2005 sp0.0 and it works fine.
If you don't have the latest SP then I recommend upgrading and then trying it. It might have been a bug in the SP you are using.
A man should look for what is, and not for what he thinks should be. -Albert Einstein
A person who never made a mistake never tried anything new. -Albert Einstein
In the assembly, insert a Feature Driven Pattern.
Ken
SW does not follow a Curve driven pattern in SW04 or 05. This an SPR and has been here since SW04. The Feature driven pattern will work with every type of feature pattern except a Curve driven pattern.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Scott,
Thanks for the tip. I've never actually tried that senerio.
Ken
