Point Coordinates Question
I am running NX2 to create part prints.  I used to use a grip program to add XYZ Coordinates, but heard that GM Toolkit now does it better.  The newest toolkit is now installed.  I have the XYZ Coordinate Button in my menus at the top of the screen, but it isn't selectable.  After adding views to my drawing and points to my hole centers, what steps do I take to use the gm toolkit button to add the coordinates?  Thanks for you help.
RE: Point Coordinates Question
Unless you work for GM, you probably don't have that program, as it is not distributed with the Supplier Toolkit that I am aware of.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
