Replace Winglets with Vertical Tail for Canard
All the old books for aircraft design are basically for a forward wing aft tail arrangement. How do I calculate the tail size and power for a canard?
The original aircraft has only winglets. What I want to do is remove the winglets and replace them with a single vertical tail.
Roger
Roger
RE: Replace Winglets with Vertical Tail for Canard
Chester
I'd check into why the winglets were used in the first place before making this mod.
Cheers
John
Yaw stability is basically the same for canard and conventional aircraft. It's been a while since I did aircraft stability calculations but if I recall correctly dynamics are an issue of the lateral lift and yawing moment generated by a side slipping fuselage, the righting moment generated by the vertical stab/rudder, and the yaw moment of inertial of the aircraft. I don't think the wing configuration changes anything in this equation other than minor changes to the yaw moment of inertia. Static stability either. You should be able to calculate the aircraft yaw dynamics using those old texts.
