Excel Worksheets.Add
These used to work just fine but now I get an error:
Set Summary = Worksheets.Add
Summary.Name = "Summary"
Set NewSheet = Worksheets.Add
NewSheet.Name = "Spec_Summary"
I get:
Run-time error'1004'
Method 'Add' of object 'Sheets" failed
Any ideas on what caused this or what I can do to fix it?
Roger
I get:
Roger
RE: Excel Worksheets.Add
Looking at the ToolPaks available here, a couple have appear to be VBA related, i.e. Analysis ToolPak - VBA.
The above probably doesn't apply, but might be worth pursuing.
-InspEngr
Cheers,
Joerd
You are right as always. I can't insert a worksheet manually. However, neither the workbook or worksheet is protected as far as I can tell. I can open, edit, and save without a password and it's not shared; but I can't insert a worksheet. What am I missing?
I figured it out. I had locked a few cells and password protected as a test. I placed this out on the network so others would have access and we were playing around with security ideas weeks ago. I forgot to remove the protection when we were finished. I took a stab at passwords for awhile until I got it right. It was something I've never used before or since so blind luck and stupidity has saved my butt again. Now where did I put those lottery numbers.
