installing CosmosWorks 2005
I am attempting to install CosmosWorks 2005 on a machine which has SW2004 and SW2005 already loaded. When I try to initiate the install of CW I get an error saying that CW will not work with the SW 2004 installation.
At the suggestion of my VAR, I renamed the SW 2004 executable file and tried to install CW. This yielded a different error about an interrupted installation which needed to be completed by running setup again (which I thought I was doing by trying to install CosmosWorks).
Short of uninstalling SW2004, installing CW2005, and reinstalling SW2004, does anyone have any suggestions?
BTW, I need both installations of SW on this machine.
Dave Gowans
Dave Gowans
RE: installing CosmosWorks 2005
You would probably have it all completely installed, by the time you get a workable solution... but I think this is your solution.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
