export to DXF
export to DXF
export to DXF
I am using UG NX 3, just converting over.  But when I export to dxf it translates the center lines, dimensions and curves but it does not translate the model.  I tried moving everything in the drawing into the same layer but for some reason I cannot get the model to show up.
RE: export to DXF
Where I am at we are stil on NX2,  But this should work with NX3.
1.  file export CGM.
2.  Creat a new part and import the CGM.
3.  Then export to DXF.
Hope this helps...
Jeremy
RE: export to DXF
thank you very much.  I should have asked you earlier before messing around forever.  I skipped NX2 and just started with NX3 but I miss the simplicity of NX 1.  NX 3 just seems to want to do everything for you when it really shouldnt.
I appreciate your help.
