Check in weld beads in sw
I have about 500 weld bead in my assembly
How can I check in them considering that I have the same names in pdm (bead1,bead2,....,bead500)
Should I rename 500 file name to obtain unique name to check in ?!?
RE: Check in weld beads in sw
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
With that done, you can easily check them in to pdm.
The prefix option may only be available when copying files, but I would recommend investigating that route.
Scott Baugh, CSWP
FAQ731-376
