Move drawing view
Move drawing view
Search function did not turn up anything, so:
Is it possible to move a section view or aux view from one sheet to another sheet? Breaking the alignment and dragging the view to another tab or within the parts tree did not work. Re-creating the views on another sheet and then deleting the parent view did not work as all the related views get deleted along with it.
A related question would be if you could move a dimension from one view to a view on a different sheet.
Thanks. This is for SW2005. I am making the transition from SW2003.
John Woodward
John Woodward
RE: Move drawing view
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Still could not drag it to another sheet. However, after several more attempts I managed to drag it within the parts tree. I just had to move the cursor to the side to allow it to change to an arrow pointing at the drawing sheet.
