>100hp hydraulic power packs
Anybody know of equipment or designs for gasoline engine power (non hydrostatic) to hydraulic power systems (vane/gear/piston pump)of > 100 hp? ie. Car engine shaft power to all hydraulic pump power.
Most commercial systems seem to top out at ~ 10hp.
Thanks.
RE: >100hp hydraulic power packs
Not much help but they must exist, as some very large vehicles use hydraulic wheel motors as their transmission.
Cheers
Greg Locock
Aren't Bobcat skidsteers hydrostatically driven?  Try a construction machinery or farm machinery parts store.
Steven Fahey, CET
"Simplicate, and add more lightness" - Bill Stout
If I remember from my younger years, you could buy standard "pump drives" to mount direct to the bell housings of any motor. When I was looking at them you could get them in a number of configurations (2-5 pump mounts) and different size drives for each. They were realitively standard components and mount sizes.
Sparweb is correct, and I believe that skidsteers use this type of mount (many of which are 100 hp+). Bobcat, New Holland, John Deere.
Excavators also exclusively use hydraulics for power transmission. If you are looking for something used, I would start with these (the power unit is somewhat isolated).
No reason you couldn't machine a mounting flange for any bell housing to which you would add a coupling and a pump.
