Ansys Error
Ansys Error
Ansys Error
Hi!
I'm trying to run a Modal analysis but ANSYS stops with the following error:
PCGLSS0055:2194320 bytes(sizeToBeAllocated 2194304+init_offset 16).
 ANSYSMALLOC failed.
Could someone tell me what's going on?
Thanx!
RE: Ansys Error
Are you using the subspace method for modal extraction? Do you have to use the PCG solver? Have you tried using the default Block Lanczos (eqslv,) first?
RE: Ansys Error
Hi again, Drej asked me for more details about my problem:
I'm using the Block Lanczos (eqslv).
