RF Loss underwater source of data
Can anyone direct me to data on RF propagation loss underwater, specifically sea water. I found one reference and would like other sources. Frequency range of interest is 1-100 Mhz.
kch
kch
RE: RF Loss underwater source of data
<nbucska@pcperipherals DOT com> subj: eng-tips
read FAQ240-1032
In fresh water it's alot better propagation, I've measured previously 10 dB per inch loss at 2.54 ghz.
Hence I'm looking for corroborating data on the under 100 Mhz frequency band.
I know the salinity varies depending on which ocean you are in, so loss versus different salt content would be good.
kch
118 KHz 9.2 dB*
3 MHz 5.7 dB
12 MHz 2.8 dB
16 MHz 11.8 dB
49 MHz 33 dB
*--used a less efficient rod type antenna, is probably better than this
the curve I obtained from the internet shows about 35 dB loss at 100 mhz and 20 inches distance for fresh water. Thanks for the info, it at least shows a correlation to the chart I have, even though they don't go to your longer distance. There's not much data out there.
kch
Why do you need to do it? Do you have to xfer info or power? what is the info content?
read FAQ240-1032
the attenuation loss should be a monotonically increasing function of frequency, the loss increasing because the skin depth is decreasing. Your data does not reflect this change. I suspect the reason is that the water is detuning the antenna horribly and making a mess of the results. It would be necessary to set up the transmit antenna under water then change the position still under water, taking the difference in attenuation that way. This also eliminates the problem of locating the phase centre of a wideband antenna at different frequencies. Remember that the dielectric constant of water is huge (40 or 80 as I recall) so it will change the electrical length of the antenna tremendously.
The signal is given by
V=Vo * exp(-a*d)
a standard exponential decay from an initial value.
d is the distance
a is 2*PI*sqrt(mu*sigma*f)
although they are using (obsolete) electromagnetic units.
I expect that you will find that particular frequencies will be attenuated more rapidly than would be expected from the formula due to molecular resonance. This will probably not happen until microwave frequencies though.
I have to digest the data before I summarize it.
kch
Have could you summarize the data you found in the IEEE journal? I'm interested in this topic.
