Eliminating features above countersinks
In the following image you can see how some features project over the countersinks:
Since I place the countersunk holes in a face lower than the overhanging features, I'm not sure how to extend the countersink up so that the features don't overhang.
I was hoping I wouldn't have to resort to some kind of conical cut extrude.
RE: Eliminating features above countersinks
Create a plane where you want the CSK to start from, or use the top surface of the trapezoids & recess or enlarge the CSK to suit. The Hole Wizard has a feature under Head Clearance & Type which allows an Increased C'sink or Added C'bore
Moving the hole up and down the tree didn't help.
Instead, I changed the sketch plane of the hole to the top of the teeth, and added a counterbore the same length as the height of the teeth from the "deck."
Looks like this:
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Scott Baugh, CSWP
FAQ731-376
