Replacing components in an assembly
I have an assembly in which I am trying to replace a part with a sub-assembly. I right-click on the component I am trying to replace and select "Reload". In the dialog box that opens up, I select "Replace" and browse to the sub-assembly I want to insert. I get the error: "File name entered was invalid, not found, locked or incompatible type". Why could this be happening?
I double checked the following:
1. The new file is indeed there, i.e it's not missing
2. File name doesn't contain any not-allowed characters.
Thanks for your help.
RE: Replacing components in an assembly
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Right-click the part in the feature manager tree and create a new subassembly. Then replace the new subassembly with the subassembly of your desiring.
http://www.EsoxRepublic.com
mncad
Scott Baugh, CSWP
FAQ731-376
