rotational spring for a pile cap
I am looking for a method or reference for calculating the rotational spring value for a pile cap in sandy soil. The soil about 4 feet below the bottom of the pile cap is liquefiable.
Is it conservative/sufficient to multiply the rotational spring for an individual pile by the number of piles in the pile group to arrive at a rotational spring value for the pile cap?
RE: rotational spring for a pile cap
Naturally, when a structural engineer is presented with a liquefaction as a possible soil failure mode, the response of the structure is assumed to be driven by the stiffness of the foundation including the contribution of the pile group. This assumes, of course, that it is somewhat deeper than the liquifiable zone else there is assumed to be rigid body translation and or rotation.
Once the soil stiffness is no longer included in the analysis, the foundation stiffness may be computed similar to a structural matrix formulation. Having said that I don't believe that all values of stiffness (three orthogonal translations and rotations) will sum. The values for the translation will as you might expect. For a circut analogy - resistors that are in parallel will sum but not those in series.
As for references, Many of the reports that I have read mention, amoung others, Gazeates and Lam and Martin. As I come across others I will post those as well.
You should be able to find much information on the modelling aspects by perusing the following databases: EERI's Earthquake Spectra abstract search, EERC at Berkeley (also at www.eeri.org), and MCEER's quakeline database at University of New York at Buffalo.
Also, please note that the other name I mentioned should be Gazetas.
Good Luck.
