Titan and Hastalloy C22
HI!
I have a small question that I hope someone can help me answer.
I want to connect an flow-element made of Hastalloy C22 into a Titan piping.
Is it safe to do that?
If not why?
Regards Roger F
If not why?
Regards Roger F
RE: Titan and Hastalloy C22
What is the fluid that you are handling?
If there is chance for galvanic corrosion you should not do it.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
Yes
The fluid is Seawater with 300 ppm Hyprocloritt
Will this information help you to say yes og no?
Roger
