Material hardness level effectiveness on thermo-conductively
Greetings,
Does the hardness level of mild and stainless steel have any effect on the thermo-conductively properties?
Concerned heat exchanger manufacturer.
~Soxfan
RE: Material hardness level effectiveness on thermo-conductively
Not to an extent that matters.  Hardness may effect the corrosion resistance, fatigue and strength of the material.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
To corroborate what EdStainless has said, here is a table from the literature showing some values:
                                          HV Hardness      Thermal cond.
                                               kg/mm2            W/(mK)
Plain CS low strength                   140                  16
Ditto high strength                       220                   25
LCS hardened AISI 4340               560                  42
Martenisitic (Cr-Ni) 630 (17-4 PH)  470                  17
Austenitic (Cr-Ni) AISI 304            160                  16
                AISI 316                      160                 16
Tool steel M-2 Hardened         (830-930)            21.3
