Hidden Line Color in Assembly Files
Anybody know how to get the hidden lines to go along with the respective part color...rather than *all* coming in as gray? I can't seem to remember where this is at.
Ken
Ken
RE: Hidden Line Color in Assembly Files
Part = Tools\Options\Document Properties\Colors\Hidden - You can change the color here for hidden lines of a part.
If you check mark the option "Apply same color to wireframe, HLR and Shaded" then the same color will apply to those areas, but hidden lines are not and option there.
Assembly = Tools\Options\Document Properties\Colors\Hidden - If you change this color all hidden lines in the assembly will change to that specified color.
There is no where that I can find to do this within the options.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Thanks for the input,
Ken
