Laser Grading
Laser Grading
Laser Grading
  Laser Grading
      #528118 - 11/11/04 04:53 PM   Edit     Reply     Quote
I’m considering purchasing some type of laser controlled grading attachment. Would like to have some input about the good and bad of different boxes or graders. Also opinions of best type of set-up (automatic machine control, receiver on rod, dual or single slope, ect.. As long as were asking questions, Best all around machine to use. Would like to do primarily commercial flatwork preparation (Grading and compaction). Would like to use something in the lines of a Bobcat T190, ASV 50 or 60, or a Cat 257. For the attachment, it would be either a Box Blade and, or Grader Blade. Would like to fit the niche of taking the sub-grade from +/- .1’ to +/- .25’ prior to pouring the concrete slab. Some of this work could be inside buildings.
Thanks, Bud
