SE & VB How i can save properties
i be able read the property with VB but i can't save it.
I want save with VB the custom property
for exsample "Long" = 100.0
Can someone help me?
In solid edge SDK is not example for this.
I try it write like this:
CODE
Sub Main()
        Dim objApp As SolidEdgeFramework.Application
        Dim objDoc As SolidEdgePart.PartDocument
        Dim objProp As SolidEdgeFileProperties.Properties
        ' Report errors
        Const PI = 3.14159265358979
        ' Create/get the application with specific settings
        On Error Resume Next
        objApp = GetObject(, "SolidEdge.Application")
        If Err.Number Then
            Err.Clear()
            objApp = CreateObject("SolidEdge.Application")
            objDoc = objApp.Documents.Add("SolidEdge.PartDocument")
            objApp.Visible = True
        Else
            objDoc = objApp.ActiveDocument
        End If
        ' getting the properties object of the part document
        objProp = objDoc.Properties
        Call objProp.Add("Long", 100.0)
        Call objProp.Save()
        ' Release objects
        objApp = Nothing
        objDoc = Nothing
        objProp = Nothing
    End Sub
Please help me?
RE: SE & VB How i can save properties
It looks ok to me apart from I have specified custom.
i.e.
objProp = objDoc.Properties("Custom")
I have done this for draft files so not sure if it will work in the part properties.
Hope this helps.
Craig
