Project stuck. 100%smoke filter materials?
Hi, this is my first post so i hope im in the right area.
I have a project im working on that has become a little stuck. I need to find materials that can capture 99%+ of basic smoke particulate from a cigarette, particle sizes that i understand range between .01 to 10 microns. I could use any recamendations anyone might have. Thanks for the help.
M00se.
M00se.
RE: Project stuck. 100%smoke filter materials?
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
Thye smoke materials being filtered are varied and you need several stages of filtration.
Activated carbon filters can be impregnated with various chemicals to 'pick out' different gases.
A multi layer filter is therefore best.
Also a pre-filter is need and a HEPA.
Good luck
Friar Tuck of Sherwood
I dealt with Bingo Halls, and lemme tell ya, those are smoky places. All the previous posts are correct in terms of installing a Dust Collecting or Mechanical Air Filtration system with an integrated multi-level filters. (1) A metal mesh washable pre-filter will catch bigger particles and save your expensive filters. (2) I suggest a horsehair or pleated polyester (washable with air gun) filter to manage smaller particles. (3) The smoke is handled with a dense (60-95%) pocket filter.
Maintain your pre-filters regularly and inspect your pocked filters periodically, and you'll have a solution!
Anh-Tai
www.maxairsystems.com
Don't have to buy filter element but you do have to wash em down
Dan Bentler
