Smart Dimension/Sketch
How do you cut the "modify box" on when in sketch mode or dim. part?
RE: Smart Dimension/Sketch
If you are asking how to prevent the Input Dimension or Modify Dimension box from popping up after you dimension something do this:
Tools-> Options-> System Options-> General tab
Uncheck "Input dimension value"
If you are trying to access the "modify box" after a dimension is made, simply double click the dimension.
