3dface/3dsolid/3dpolyline using VB - Need help
Here is what I am trying to do:
I have .DWG (from mechanical desktop)files that have both 3D & 2D entities in them. not able to export(step or iges) the complete data out of Mechanical desktop. If I use step, I am losing 2d drawing data. If I use IGES, i am losing 3d data.
I would like to: (through VB )
scan all the .DWG files. If 3D entities are found, export them into STEP. If 2D entities( pure 2d drawing )are found, export them into IGES 2D.
If someone has some sample code for searching entities both in ModelSpace and PaperSpace, please post it here.
If you have some other ideas, please share with me.
Thanks in advance.
y2kmvr
RE: 3dface/3dsolid/3dpolyline using VB - Need help
This is made from some pieces of code I use....no promises.
Public Function Get3dObjects()
'Get3dObjects:
Dim acSelSet As AcadSelectionSet
Dim iCode() As Integer
Dim vValue() As Variant
'Filter set
ReDim iCode(4): ReDim vValue(4)
iCode(0) = -4:  vValue(0) = "<OR"
iCode(1) = 0:   vValue(1) = "3DFACE"
iCode(2) = 0:   vValue(2) = "3DSOLID"
iCode(3) = 0:   vValue(3) = "POLYLINE"
iCode(4) = -4:  vValue(4) = "OR>"
Set acSelSet = GetMultiEntSS(iCode, vValue)
End Function
Public Function GetMultiEntSS(ByVal vFiltType As Variant, ByVal vFiltData As _
Variant) As AcadSelectionSet
'GetMultiEntSS: Select from all entities and return selection set of all items
'               of the type provided
'Arguments:     vFiltType:
'Returns:       AcadSelectionSet
'Example:
'ReDim iCode(3): ReDim vValue(3)
'    iCode(0) = -4:  vValue(0) = "<OR"
'    iCode(1) = 2:   vValue(1) = "SOMEBLOCKNAME"
'    iCode(2) = 2:   vValue(2) = "SOMEOTHERBLOCKNAME"
'    iCode(3) = -4:  vValue(3) = "OR>"
'    Set acSS = GetMultiEntSS(intCode, vntValue)
Dim intMode As Integer
Dim vntFilterType As Variant
Dim vntFilterData As Variant
intMode = 5 'acSelectionSetAll
Set acSelSet = ClearSS("MSSET")
vntFilterType = vFiltType
vntFilterData = vFiltData
acSelSet.Select intMode, , , vntFilterType, vntFilterData
Set GetMultiEntSS = acSelSet
Set acSelSet = Nothing
End Function
Public Function ClearSS(ByVal strName As String) As AcadSelectionSet
'ClearSS:       The input selection set name is deleted from the drawing so
'               that the selection set name can be reused.
'Arguments:     strName - name of selection set to create in the drawing
'Returns:       Returns the selection set, cleared of all items
On Error GoTo ErrHandler
Dim acSelSets As AcadSelectionSets
Set acSelSets = ThisDrawing.SelectionSets
For Each acSelSet In acSelSets
    If acSelSet.name = strName Then
        ThisDrawing.SelectionSets.Item(strName).Delete
        Exit For
    End If
Next
Set acSelSet = ThisDrawing.SelectionSets.Add(strName)
Set ClearSS = acSelSet
ExitHere:
    Exit Function
ErrHandler:
    Debug.Print vbObjectError + 514, "PP_ACAD Error", _
    "Function 'ClearSS' Failed"
End Function
"Everybody is ignorant, only on different subjects." — Will Rogers
