Centerline Symbol
Centerline Symbol
Dear Folks;
I created a simple text based centerline symbol by using a small letter C and large letter L and then grouping them together. I was wondering if it can be saved for future use and dragged into the drawing as required.
I'm using SW2005 SP0
Best Regards
Adrian Dunevein
www.aaadrafting.com
Best Regards
Adrian Dunevein
www.aaadrafting.com
RE: Centerline Symbol
It seems like alot of unnessary work.
Look in SW Help for "symbol" or "symbol library"
Once the symbol is created as a note then you can save it as a favorite and then bring it into the drawing any time you want.
A man should look for what is, and not for what he thinks should be. -Albert Einstein
A person who never made a mistake never tried anything new. -Albert Einstein
To add a something to the folder you just drag and drop it the first time. I have found that in blocks that I have used model properties it associates those as well when you drop it into the new drawings. You it on castings quite a bit.
One thing I would like to see...
In UniGraphics, it was possible to embed custom symbols into files and templates, so there was no dependency on external libraries.
Just a thought....
http://www.EsoxRepublic.com
Then there are the text symbols that come with Solidworks located in the Solidworks folder.
Jason Capriotti
Smith & Nephew, Inc.
the simplist way to get the symbol in a drawing is type the following in a note OR dimension:
<MOD-CL>
or, right click the note, select properties, click on "add symbol", (modifying symbols library), select "centerline",
click OK
click OK
Thats exactly what I was looking for !
Best Regards
Adrian Dunevein
www.aaadrafting.com
