Equivalence between FAG and SKF Bearings
Hello, Does anybody has information about a table in which equivalence between FAG and SKF bearings is available?.
I would appreciate your help ASAP.
RE: Equivalence between FAG and SKF Bearings
Yes, go to www.fag.com look for the bearing interchange system.  You will have to create a user name and password to use the system, but it should have the information you are looking for.
I am pretty sure you can do the same thing at www.skfusa.com
I am pretty sure the numbering is close.  If you tell either  one you want a 6313 with C3 internal  clearance, double-shielded, they would know what you want.
