Rebound Springs
Rebound Springs
How do they work? I have a small understanding of them but would like some other feedback/info.
RE: Rebound Springs
On heavy vehicles, the forces on suspension components can be large when the wheel is suddenly unloaded (ie when it hangs over a void - frequently happens on off-road applications). A rebound stop is often simply the damper running out of travel and providing some metal-to-metal stop internally - not nice. Sometimes there is a check strap (wire cable or suchlike) which goes taut when the rebound travel limit is reached. Alternatively, a rebound stop, like a bump (jounce) stop, can be a rubber spring, a disc spring or whatever. I believe some German vehicles used volute springs as rebound and bump stops.
So unless 'rebound spring' has another meaning I'm not familiar with, it's just a more sophisticated way of stopping the rebound travel when the suspension runs out of 'droop'
John
RE: Rebound Springs
I'm not going to provide a tutorial on them, but if the initial poster asks more direct questions he'll get a more direct answer.
Cheers
Greg Locock
RE: Rebound Springs
In Particular, sedan road going passenger vehicles with low roll stiffness from sway bars etc to keep good articulation and wheel independent-ness. I.e. it’s no point going to all the trouble of making 4 wheel independent suspension and then tying them together with thick sway bars to stop excess roll (and pitch if a front to rear sway bar were to exist). If a rebound spring de-rates the overall spring rate of that wheel as it goes into droop (unloads) it would be good to have less force there when it does encounter a single wheel bump. My question is I have heard they work very well particularly for heavy vehicles, how do they work in controlling roll?
Travers
RE: Rebound Springs
Cheers
Greg Locock
RE: Rebound Springs
Subaru Outback (Front only), Ford BA Falcons, some Jags, many BMWs are all users of these systems, there must be more to it than stopping the suspension topping out suddenly?
And as OSVALDO mentioned they tend to work very well on heavy vehicles but I am lead to believe you can make small vehicles handle exceptionally well with very little roll and no anti roll bars.
I am looking to use them on the Suspension I am designing for my Suabaru outback, Mainly a replacement of original shocks with custom made Bilsteins, with more progression in the overall spring rate (OE spring plus bounce rubbers, active close to ride height as mentioned in previous threads - they do work very well) and if I work them out rebound springs)
Look forward to any responses.
Travers
RE: Rebound Springs
Cheers
Greg Locock
RE: Rebound Springs
RE: Rebound Springs
