Sweep along guide
Sweep along guide
I am using NX2 and I am trying to do a sweep along guide but I need some help.I have a closed loop as my section string and also a closed loop as my guide string.I placed my section string in a corner of the guide string and when I do the sweep it has a missing part(corner) just behind the section string.Can someone please explain what am I doing wrong?
RE: Sweep along guide
When I placed my section string at a midpoint of the guide strings,no section was created from the section to the corner of the guide string.
Grant
Aerospace Engineer
I seriously doubt if that will make a difference. You'll probably have to resort to using Free Form Feature Swept & use point to point orientation to make sure the corners maintain their shape. Maybe even add additional guide strings.
See UG documentation for the different
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Yes,my section strings are planar.
I tried using Free Form Sweep but I am having an error saying "sweep section or guide curves are ambiguous"
