Stress Concentration Factor
I am trying to plot stress concentration factor for a rectangular beam (6x1.5x.25) with a hole .25 dia in the center of the largest surface. I constrained the beam at one end and applied a 100lb load  at the other. I want to know which is a good location to look for nominal stress. I want to iterate this for different hole sizes on the same plate. If I pick the location for nominal stress away from the hole like say near the constraint or near the load then the stress is not changing much at that location with a change in the hole dia as a result my Kt is increasing with bigger hole instead of decreasing. Thanks in advance.
Joe
RE: Stress Concentration Factor
A better way might be to plot stress ratio vs. a beam with no hole in it.
For a beam under bending it would be easier to work out the nominal stress by hand.
corus
Thanks btureblood and corus. I did not use the hand calculated values because I wanted to see the Kt curve purely from FEA results. If I compare the stress of the beam with hole to the one without hole I would have to model the beam without hole in such a way that the net area of cross-section is the same in both the cases which is not a problem but i wanted to get all the stresses from this one beam. I forgot to mention in my question that the load is axial along the lenth of the beam. Thanks
Joe
The stress near the constraint or load shouldn't change at all if the beam is long enough. If the stress concentration is getting larger for a larger hole then you're probably getting edge effects as the amount of load bearing material reduces between the hole and the edge of the beam.
corus
I am looking for a beam equation for a propped cantilever beam.  All the equations I have found show the load in the middle and the prop at the end.  In my case I need the prop in the middle and the load at the end.  Can anyone point me in the right direction.  Thanks!
--Kevin
Try looking in Roark, kreker. If a beam is propped in the middle and you apply a load at the end then it falls over by the way.
corus
I would suggest investigating a few sample SCF problems with known solutions. The question of where to pick the location to define Nominal stress is always tricky...
David R. Dearth, P.E.
Applied Analysis & Technology
