drawing circles, splines and stuff in mechanical desktop 2004
Hello
I am running MD2004 and when I want to draw a circle or an arc, ellipse, spline,... I can never see the shape change as I move the cursor during the command, like when I am drawing a spline on the view I cant see if its good what I am doing, kinde strange, even when I am copiing or moving an object I can never see the object that I'm moving or copiing, so it's a bit difficult like if I forget what I've used as basepoint.
Does anyone know the answer to that problem?
RE: drawing circles, splines and stuff in mechanical desktop 2004
Just type HIGHLIGHT at the command prompt and set the value to 1.
This should fix your problem.
Trav :)
Nope, it didn't :-(
Check the dragmode setting.  If it is off, set it to Auto.
