Pro/Cabling query
Pro/Cabling query
Pro/Cabling query
Hi All,
I just started using pro/cabling (2-3 days back!!) and could route few wires using Datum points.
The problem I am facing is that I have terminated the wire at an un-intended place and if I move the point to the required position, the wire sags. My Questions are-
1) How do we 'extend' a wire/cable already routed to a new
   desired location.
2) how can we add points in an existing cable/wire (routed
   through a series of points) so as to get a better
   control over the routing.
3) If I want to "strip" a length of wire to show bare
   copper metal, What is the best way to do it? I am at a
   loss to figure out a way to cut wires genereated in
   Pro/cabling!
Thanks in advance,
Jaya
