attaching carbon fiber panels to a mild steel frame
I could use some advise on how to best prepare a mild steel frame for attaching a carbon fiber panel. The panel will sit inside the frame and carbon and kevlar tape and epoxy will be used to bond the panel to the frame. I have read that degreasing, then etching for 10 minutes in 15% hydrochloric acid and then rinsing will prepare the metal. Is bonding directly to bare metal best? I would prefer to coat the metal with something that protects it from corrosion and provides a good base for the epoxy.
Thank you
Thank you
RE: attaching carbon fiber panels to a mild steel frame
The joint will only be as strong as the weakest bond in the load path.
If you paint the metal, then glue to the paint the weakest bond will most likely be paint-to-metal. Not too strong typically.
We used to do a mechanical abrasion (180 grit), wipe with Methyl Ethyl Ketone, dry, join. You may find that you are not allowed to use MEK.
I haven't come across an acid etch process before.
I'd paint over the completed item, for the reasons MintJulep gives.
Cheers
Greg Locock
You don't need a coating prior to epoxy - it will adhere very well to bare steel. You can use epoxy-based paint to coat the entire assembly if desired.
Cory
