Dimensioning where an apparent intersection is
Can anyone tell me if it's possible to dimension for example the top of a taper which has a fillet,i.e. apparent intersection of the taper and the horizontal.Does that make sense.
RE: Dimensioning where an apparent intersection is
Oops... Ctrl-select the the two line segments and then click the Point icon on the Sketch Tools menu.  This will create a virtual corner that you can diemsion to in drawings.
"But what... is it good for?"
Engineer at the Advanced Computing Systems Division of IBM, 1968, commenting on the microchip.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Thanks MadMango for the tip
You can also change how it is represented in the tools, options, detailing menu, and virtual sharp.
