achieving 250 bar compressor pressure
How can I design a 250 bar maximum pressure piston pump for compressing natural gas with a small flow rate? Thanks for replies.
Daniel
Daniel
RE: achieving 250 bar compressor pressure
Pumps pump liquids. Compressors compress gas. I seriously doubt if you will find a piston pump that will compress natural gas. The liquid head produced by a pump might be used to compress a gas downstream, but the pump itself can't compress gas.
Can you explain the details of your design? This will be a revolutionary first.
Art Montemayor
Spring, TX
How low is a low flow?
