Modify a sketch
Modify a sketch
I am using NX2 and I am trying to modify a sketch which is already extruded and I am having an error saying "The selected objects are not supported by this operation".
How can I modify the sketch without deleting the extruded body?
RE: Modify a sketch
Create the extra needed curves in the sketch, choose add/remove objects from string, using shift-MouseButton 1 to remove objects and MB 1 to add objects.
Make sure your string as closed if it was closed before the edit, then choose "update model" or exit sketch which will also update the model.
After the update, you can remove unused objects from within the sketch.
Erland R. Nielsen
Denmark
RE: Modify a sketch
RE: Modify a sketch
This brings up a list of features that use the sketch.
Highlight the feature in question (not needed if there only is one) and then use MB1 and shift-MB1 to add and remove string objects (individual curves)
Erland R. Nielsen
Denmark
RE: Modify a sketch
Caruana
