ductile-brittle transition temperature
Guys, who knows the ductile-brittle transition temperature for steel AISI 1050?
RE: ductile-brittle transition temperature
Typically, the higher the carbon content in steel, the higher the ductile-to-brittle transition temperature (DBTT). I would estimate that the DBTT @50% flat fracture for carbon steel with 0.50% carbon is about 100 deg F. This value is based on my picking off a data point from a graph of Charpy V-notch impact values versus test temperature for various plain carbon steels with varying carbon contents (0.11% to 0.67%).
For a general idea look in the ASM Metals Handbook Vol.1 in the chapter on Notch Toughness of Steels.
Considering how low the toughness of this grade will be to start with you do need to be careful.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
