Wildfire "line style" "pick many"
Hi all!
I'm using Wildfire 1, and becoming very frustrated that I cannot pick curves for line style modification like we used to ... you used to be able to pick everything within a rectangular area. Other than modeltree picking, and curve by curve picking, can anyone suggest how to pick a bunch of curves (in this case, on imported dxf data) to modify?
Many Thanks!
Chris
RE: Wildfire "line style" "pick many"
We are using Wildfire2, so this may not help.
Select the curve as a feature or from the model tree, right click the mouse and select PROPERTIES, the line style is in here.
Hope this helps.
maybe only a drafter
but the best user at this company!
Chris,
Did you try pressing ctrl while you are selecting the curves?
Thanks.
