Note in drawing & reference to subassembly instead of part
I've got a drawing view of an assembly which contains subassemblies.  I have a note w/ leader that I would like to use to call out one of the subassemblies, but it only will reference the part it's touching.
Is there a way to tell the note to reference the subassembly instead of the part?  Thanks,
Brian
RE: Note in drawing & reference to subassembly instead of part
Not sure if this will work but try showing a plane in the sub-assy and attach to it.
Jason Capriotti
Smith & Nephew, Inc.
what information do you want to show about the sub-assembly on the drawing?
-part number
-Item number from BOM
-description
Is the information you want to show stored in a custom property of the sub-assembly?
I have submitted an enhancement request for this about 2 years ago, still no luck.  Not sure about SW05 though, we haven't upgraded to that yet.
I just tried this and it worked!
Make a sketch in the subassembly.  Make sure the sketch is visible in the drawing.  Attach the note leader to a sketch curve.
Use selection filters or hide components to make sure you are grabbing the sketch curve.  The sketch can be a 2D sketch on a component face.  Another possibility is to use a 3D sketch and use "Convert Entities" on a single component edge.
"An object at rest can not be stopped."
http://www.EsoxRepublic.com
