Hatch not showing in croped or broken views
I'm able to apply a hatch to cropped and broken views but you can't see it. I select the face and apply the hatch settings like normal. Whne I apply the hatch it disappears. SW says it there but you can't see it. unbreak or uncrop the view and it appears???? Getting on my nerves!!
RE: Hatch not showing in croped or broken views
Macduff
Meggitt Airdynamics Inc.
Dell Precision 370
SW2004 Pro SP4.1
XP Pro SP2.0
NIVIDA Quadro FX 1300
Changing hatch size or type, does it have any influence?
According tot he website this combination is supported by SW.
The solid hatch doesn't wotk either. My VAR is telling me this is working fine on their machine. It only does it on some files. Files I have converted form 2003 seem to be having the issue.
If that doesn't fix it, then try turning your hardware acceleration down to none. Desktop - RMB\Properties\Settings\Advanced\Troubleshoot tab\ - Pull that slider all the way down.
Report here the results of both tests.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
hope this is of some help. Glad to see we are not the only ones seeing it.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
