Disapperaing sketches
Anyone else having problems with sketches not showing or disappearing while modifying in SW2005. I'm specifically having problems with the circle and modify sketch tools. I select the circle tool and click for my location. The circle dosen't show like it should but when I click the second time it appears. The you dimension the circle and the dimension shows briefly and then disappears until you click to place it and then it's back. The tools are working you just can't see them. I'm running a supported video card on the newest driver.
RE: Disapperaing sketches
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Scott Baugh, CSWP
FAQ731-376
The sketch reappears visual when you switch to one of the wireframe modes.
Morten K. Thillemann
"But what... is it good for?"
Engineer at the Advanced Computing Systems Division of IBM, 1968, commenting on the microchip.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
