wastewater flowmeter
Im looking for a flowmeter for wastewater application. it will be in line and built on the discharge pipe (6 inches diameter) Does anybody have experience or suggestion?
RE: wastewater flowmeter
thanks for replying.
siblak
The mag meter will not work on a partially full pipe.
Another option is an ultrasonic flow meter. With area and velocity readings, it can give a flow for a partially full or full pipe.
Any experience with Rosemount Flowmeter?
If it does not flow full, maybe a Parschal flume.
I have not had consistently good success with ultrasonics in permanent installations. Flow is affected by TSS in wastewater.
Rosemount is a brand of instruments, not a type of flow meter. I don't know what kind you are referring to. Rosemount is generally good.
