newbie counterbore question
I'm trying to create a counterbore hole but wild fire will only let me make a threaded counterbore hole.  How can I make a standard counterbore hole using the hole feature?
RE: newbie counterbore question
Change your hole type in the drop down box from simple to sketched, then draw the hole profile as if it was a revolve (all entities on same side of centerline).  You can also save the sketch to use later.
MM
http://www.txsdesign.com/
In the THREADED section, pick the option CLEARANCE HOLE. Now you can make a hole with a counterbore.
To change the Pro/E default clearance hole diameter, pick
"hole_diamter_override" to "yes" in your config.pro.
Steve
http://www.sprdesign.com
http://www.3dlogix.com
