how to reduce size of a model
I just got a 3d model of an outboard engine, that was sized 11mb in rhino, and imported it in cati through iges, and the size of the model in catia is 44mb!!!!! that is huge.
Does anyone know how to reduce that. The main problem is that the model contains hundreds, not to say thousands, of surfaces, and when you pas over the part on the assembly, it takes a while seleting and deselecting all the part with it surfaces....
RE: how to reduce size of a model
You probably won't be able to reduce file size, but if you want to help performance, turn off "preselect in geometry window."
There's an option in the GSD workbench, under TOOLS, called DELETE USELESS ELEMENTS.  You might want to try that and see what happens.
"There's an option in the GSD workbench, under TOOLS, called DELETE USELESS ELEMENTS.  You might want to try that and see what happens."
He's working with an IGES. What will happen is it will delete everything.
Now we know what Dassault thinks of IGES.
Another trick to keeping model size down is when working with surfaces is to copy the final surface that you want and paste special as result then blow away everything before that pasted surface.
^^ Right, assuming we don't care about parametricity (which is a fair assumption if he's working with IGES files)...
The reason Delete Useless Elements is bad with IGES is this: Useless Elements are elements that aren't associated to a Body. As such, anything isolated in an Open Body (or Geometric Set) gets blown away.
ANOTHER trick for file size is to clean the model (via CATDUA in utilities). You have to be careful with this one because it also deletes things, and you have to make sure you clean with whatever licences the part/product was built with (don't clean a tubing run without the tubing licence, for example).
thanx
