hole array in wildfire
I have been using Solid Edge for several years now and yesterday I started using Wildfire 2.0. I can't seem to figure out how to make a hole array in sheetmetal. And so far I'm not impressed with the user interface for defining some of the sheetmetal features. If someone could let me know how to make a hole array that would be great. Thanks.
RE: hole array in wildfire
Dont worry about the interface, PTC changes it every couple of realeases, so once you get used to it, they will change it for you!
MM
http://www.txsdesign.com/
Wildfire has some cool new pattern functionality that pretty much gets rid of the need for driving dims and relation patterns. Although I liked the old Make Datums functionality which has been a pain for many new users the new pattern functionality should remove a lot of unneccesarry datums from display.
I think the WF2 demo site or proe-central.com has some free videos that show the new pattern tools.
I lost the direct link to the wildfire 2 demo site so If either of you fill out the form to see the tour please post the direct link.
WildFire2_interactive_tour
http://www.proecentral.com/portal/tips/playvideo.a...
if you're not a proecentral member you may need to sign up but it's free so it shouldn't be hard to get to.
Michael
MM
