threads
threads
how do you place threads on pre-made holes?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: threads
"But what... is it good for?"
Engineer at the Advanced Computing Systems Division of IBM, 1968, commenting on the microchip.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: threads
RE: threads
RE: threads
RE: threads
RE: threads
Solidworks needs to create a 3d thread function like the one in UG, works pretty good.
Jason Capriotti
Smith & Nephew, Inc.
RE: threads
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
RE: threads
Jason Capriotti
RE: threads
RE: threads
1. Make a helix, then create a work plane perpendicular to one endpoint of the helix (Insert>Reference Geometry>Plane and select the normal to curve radio button, then click on one end of helix).
2. On the new plane, sketch the thread section geometry, close the sketch
3. In browser, select the helix and the thread geometry sketch, select Insert>Cut>Sweep
Still think "printed" threads are a lousy idea, but then haven't seen whether the newer machines can give good enough surface finishes.
RE: threads
RE: threads
Scott Baugh, CSWP
FAQ731-376
