Any experience w/ high mount injectors?
I've seen a high mount injector kit to put injectors in the stacks of my ITB's. Has anyone any thoughts on this?
http://www.twminduction.com/ThrottleBody/TopFeed-F...
RE: Any experience w/ high mount injectors?
This can be counteracted by proper accel enrichment and decel enleanment.
End-of-Injection timing parameter will have greater effect on power with the injectors further from the valve, especially with duty cycles below 50%. Any standoff created by the high mount injectors must not be allowed to condense and puddle in the air cleaner or air box assembly or the risk of fire increases dramatically.
my $.02
