SHELL STRESSES RESULTS
HI FOLKS.
I HAVE A PROBLEM WITH THE RESULTS OF THE FLOORS AREAS, WHEN ETABS SHOWS THE FORCES IN THESE ELEMENTS IN THE LOWER GRAY BAR SAYS A VALUE FOR EXAMPLE 50, BUT WHAEN I PICK IN THE WINDOW TRYING TO SEE WHERE IS THIS MAXMIUM RESULT I CAN'T FIND IT; EVEN THE CONTOURS COLORS DON“T SHOW THESE MAXIMUM VALUES. I TRIED USING A REFINED MESH, BUT IS THE SAME. PLEASE I NEED HELP!
THANKS IN ADVANCED
RENATTO
