Insert Model Items - Dimensions
I typically use this command on a new drawing, after I've set up my views.  I do not do it by feature, but by the enitre model.  I do NOT check any of the subitems (Marked for Drawing, Instance/Revolution Counts, etc).  However, Hole Wizard Profile dimensions always show up (and in large quantities - a diameter and depth for every hole).  How can I prevent these from showing up while dimensioning the entire model?
Running SW 2004 SP4.1
Mike
RE: Insert Model Items - Dimensions
If you have 'hole wizard profiles' selected, deselect it. Should get rid of most of the diameter problems and the hole depth callout.
NONE of the subitems (including Hole Wizard Profiles) are selected.
hmmm....used to happen to me too.  Try a repair on SW and see if it goes away?  Good luck.
