Another DrawOrder question
I attached an image of a map to the drawing in model space.  I then go to Layout (paper space), and open a viewport to size the map.  When I add my leaders and text in paperspace, it dissappears from the display beneath the image in the viewport.  DrawOrder has no effect on elements in another space.  In other words, I can't get the leaders and text to display on TOP of the image unless I put all elements in either paper space or model space.  Print preview and plotting work fine, it just doesn't display properly.
Am I doing something wrong or is this just the way Autocad works?  I'm using 2002.
RE: Another DrawOrder question
Hi tgreif,
maybe this is a solution?
best regards, Lothar
ADT 2004
ACAD 2002
Thank you Exxit, that worked perfectly.
